anyone know where I can get hold of one of these? It's for my girlfriend who steadfastly refuses to get a widescreen Ideally 20" and cheap! MUST have 2 RGB scarts.
Unlikely as having two RGB scart sockets is a top end tv feature where as the actual spec tv your after is bottom end. Your best bet is getting a Joytech remote control AV switchbox in addition to a 4:3 set.
Here's a cheapie widescreen I found with 2 scarts. Not exactly what you wanted but you never know! http://www.currys.co.uk/martprd/sto...sku=276026&category_oid=-20094&fm=3&sm=0&tm=2
not exactly cheap but i think 2 RGB scarts... check with local dealer http://www.bang-olufsen.com/sw1208.asp
JayJay - for some reason, links to currys never work ..... HornyDragon - thanks, but the words 'cheap' and 'B&O' don't usually go together. In the end I bought a cheap scart switcher and kept the old tv until I can talk her round to getting summat decent.
