cheap 3801 or expansive 3802 ?
Discussion in 'AV Receivers & Amplifiers' started by spielberg666, Dec 18, 2001.
  1. spielberg666
    spielberg666
    Hi, I want to know if I can still buy the old 3801 and how much it costs. And second I'd like to know the price and the specyfications of the 3802.
    Thanx...
    And Cya...:eek: :eek: :eek:
  2. Lowrider
    Lowrider
    The 3802 has Dolby Prologic II, a MUST, plus variable crossover, important if you have small speakers...
    So forget the 3801 :devil:
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    18,999
    Inbetween Upgrades !
    +7,283
    Forget the 3801.
    The price of the 3802 is different wherever you go, beware of imports and warranties , stick with a dealer who is close to you if you can .
    Check out Denon's web site for spec's
    Kevin
  4. spielberg666
    spielberg666
    could you tell me what variable crossover does exactly?
  5. Lowrider
    Lowrider
    The crossover will separate frequencies, standard is above 80 hz to the speakers you define as small, below that to the subwoofer.
    If your speakers won´t play well below 120 hz, for instance the KEF eggs, you need to be able to set a diferent crossover frequency in the receiver.
  6. spielberg666
    spielberg666
    Cool
    Thanx
