cheap 32" lcd bargain for £399
Discussion in 'LCD & LED LCD TVs Forum' started by greyhorse, Mar 18, 2006.
Tags:
  1. greyhorse
    greyhorse
    Apr 16, 2005
    447
    http://www.dabs.com/ProductView.aspx?Quicklinx=3TLW
    for those on a tight budget the Classic all-in-one solution :D
    The last word in flat panel TV: dynamic design, clear lines, compact form
    Experience television viewing at its purest: your favourite films in XL format.
    All the electronics and the high quality stereo speakers have been fully intergrated in the casing. Discreet yet elegant in design, the TV is a stylish addition to any setting. The stand included in the scope of supply can be easily removed for wall assembly, allowing the display to be mounted to the wall like a picture to save even more space.
    The extremely flat, fanless screens provide unsurpassed image brilliance and sharpness. The fanless concept is based on state-of-the-art technology: there is no ventilation noise to distract you, so you hear only what you want to hear. Easy opertaion via remote control and with a clearly arranged on-screen menu.
    The combination of flat panel display technology, a high performance scaling engine and advanced de-interlace technology with special digital algorithms for optimal display of moving images offers you the ultimate television experience. The "noise reduction" feature eliminates electronic disturbance ensuring steady picture quality.
    Specifications
    Display Technology - TFT
    Diagonal - 75cm (30")
    Format - 15:9
    Active Screen Dimensions - 643mm x 389mm
    Response Time - 25ms
    Contrast Ratio - 500:1
    Brightness - 450cd/m2
    Colours - 16,770,000
    Viewing Angle - 170 degrees (vert/hor)
    Resolution - WXGA (1280 x 768)
    Input Scart - x2
    CVBS - x1
    Y/C - x1
    DVI-I - x1 (analogue RGB, digital DVI 1,0)
    RF-Tuner - x1
    Tuner Programme Memory - 99
    TV standard - PAL/Secam, BG, I, DK/K', L/L'
    Teletext - TOP/FLOF/Level 1.5
    Page memory - 252
    Audio Power Rating - 10W/7W @ 8 Ohm
    Loudspeaker - 2 x 2 Broadband
    Stereo Line Output - 1 x Cinch
    Dimensions Size - 870 x 535 x 140mm
    Net Weight - 16kg
    also some faulty, open box stocked fully repaired for £325 seems to get good reviews.
