Cheap 2nd hand 5.1: Infinity Alpha 5 vs Jamo E 310 PDD vs..???
piccobello
Hello all,
I am looking for a reasonably cheap (100-200€) second hand 5.1 speaker set, and I found two that seem interesting:
  • Infinity Alpha 5
  • Jamo E 310 PDD
Which one would you pick and why? Other similar alternatives that are easy to find in Europe? They're both pretty old so I did not find much online.
It's for a small room, I'm more interested in quality of sound (even at low volume) than in power per se as I have neighbours, I prefer small front/satellites with no or front port bass reflex as I will have to mount them on the wall. 70% music (incl jazz, prog rock, ethnic, some classical), 30% movies (mostly old so I should not bother much about 5.1 indeed, but I got used to it). I'd like something of that look, I prefer to avoid those 5.1 with tiny plastic satellites..
Thanks a lot for your advice!
piccobello
For what it's worth, I ended up getting the Infinity Alpha 5 and I like them quite a lot, I actually can keep the sub off most of the time.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
