Cheap 20w gu10's
Discussion in 'Smart Home, Climate Control & Security Forum' started by sean.pittaway, Mar 16, 2005.
  1. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    Title says it all really...
    We have loads of spots scatered around the house, 50 is way to bright, 35 will do, but 20 is perfect...
    Price wise, Ikea do 35w bulbs for 1.10 but i cant find any 20w ones anywhere near this price.
    Can anyone help?
    Cheers, Sean.
  2. mrdimmer
    mrdimmer
    be careful when using cheap GU10's if you are dimming them. Most will blow up dimmers when they blow.
  3. sean.pittaway
    sean.pittaway
    Apr 23, 2004
    83
    Cheap is relative, i dont see any reason to spend £7.50 on 2 bulbs from B&Q :)
    The 35W ones from ikea seam fine, they have been in for a while and no problems so far, it was jsut that i wanted to drop the wattage down to 20W.
    After searching around, the best price i found was at http://www.ricamstore.co.uk/
    They are "Pluslite, Grade A 2000 Hour Lamp, 36° Flood 20 Watt" and are 1.60 each, all individually boxed.
    Order was proccessed quickly, and the box arrived at my house un-mollested by the delivery men :)
