Chassis Loewe
Discussion in 'General TV Discussions Forum' started by JurgenNL, Apr 5, 2003.
  1. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    Hello,
    I bought the Loewe Aconda 93102ZW begin march this year. Now I see that it has the chassis Q2400, but the most recent one (and all available quite a while, I have heard) is Q2500H.
    Should I ask for a replace of the chassis or isn't it that important?
    Jürgen
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    It isn't that important - in fact I can't think of any features offhand that the Q2500H has over the Q2400H. If you are otherwise happy with the TV, then stick with it :).
  3. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    groundy, thank you,
    That's what I prefer, but I have read about future features(progressive scan, HDTV) and different possibilities in this respect.
    Jürgen
  4. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Those features are already available on the US spec Loewes but not on the European ones as yet. The Q2500H doesn't have them either, though it is PAL/NTSC Progressive compatible through the optional VGA upgrade. The Q2400H is only NTSC Progressive compatible in this respect.
  5. JurgenNL
    JurgenNL
    Jun 12, 2002
    282
    +20
    Thanks again.
    Jürgen
  6. Jagsta
    Jagsta
    Groundy - does the PAL/NTSC progressive apply only to the Q2500H Chassis? Is this also true of the Q2500M, or does the M chassis only support NTSC Progressive?
  7. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Not sure on that one but I would assume the Q2500M will too. Read the pros and cons of this feature here:
    http://www.avforums.com/forums/showthread.php?s=&threadid=36255
