Charging Nokia 6230 for 1st time
Discussion in 'Mobile Phones Forum' started by SuperOxford, May 19, 2004.
Tags:
  1. SuperOxford
    SuperOxford
    Dec 4, 2003
    194
    +11
    Just got my 6230 and am about to charge it. I know this is probably a very stupid question but how long should i charge it for?
    This is only my 2nd phone and i think i charged my last phone for 16 hours the 1st time but cant remember.
    Would appreciate your help! :lease:
  2. davescot
    davescot
    This reply may be a bit late now, but charge it overnight.
  3. SuperOxford
    SuperOxford
    Dec 4, 2003
    194
    +11
    will do
    thanks for your reply
  4. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    In other words, where repeated charging on older phones progressively wore the battery down to a point where the phone did not hold charge, newer models can be charged every day if you so please without any ill effect.
    A little off topic here I know, but something you may find helpful :)
    K.
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    interesting if it is true..... that is one of my biggest reasons for a new phone each year.....
    ad
  6. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    Ditto...
    I can't vouch for it's validity unfortunately but as stated, it came from a Nokia rep. and in the context of the discussion at the time there was no need for it to be untrue - it was simply a passing comment.
    I did notice on getting my handset that the battery does look different to the "classic" Nokia design. I don't know if there's any way to check - I guess time will tell :)
    K.
  7. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    I think it is because they now use Lithium batteries.
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    You could just get a new battery instead. ;)
    They've been using Li-Ion batteries for years which supposedly don't have memory problems. As with Ni-Mh. Ni-Cad were the biggest offenders particularly as they actually produced a lower voltage than standard batteries.
  9. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
  10. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    a new battery costs nearly as much as a new phone! :eek:
    ad
  11. Zor
    Zor
    Mar 17, 2003
    185
    19
    Cheshire
    And as per Mylo's link
    As much as Ni-Mh were a lot better than Ni-Cad.
    A little care does go a long way!
  12. davescot
    davescot
  13. dealmaker
    dealmaker
    Feb 21, 2001
    741
    nearly in Scotland!
    Slightly off topic here guys ...but has anyone nticed that if they turn their 6230 OFF whilst charging it loses the date and time setting?
    I've got two that do this??? :confused:
  14. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    What version software do you have? (Press *#0000#)
    K.
  15. dealmaker
    dealmaker
    Feb 21, 2001
    741
    nearly in Scotland!
    Kelvin,
    It says:
    V 03. 15
    17-03-04
    RH-12
    GSM P1.1
    (c) NMP
  16. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    3.15 is the latest version which was supposed to iron out some of the initial bugs from 3.14... I'm running 3.14 still and don't have the problem you mention so I'd suggest it's software related. I assume both phones are 3.15?
    There's not a massive amount you can do to be honest until Nokia release some new software. I can't imagine it'll be too long but it's probably worth mentioning to your retailer so he can advise you when an update is available...
    K.
