Quantcast
charging Ipod batteries
lyban
If your away from home and do not have computer with you, is there a way to still charge your batteries in the Ipod.
lyban
Thanks for the reply. Now if I am in Europe or in an African country, do you know if I can just use a plug adaptor or will there be a problem with voltage. :confused:
S
Sasso
If you have adaptors (step up or down or whatever) that are made specifically for your country's plug use in another country's socket then there should be no problem I think.
lyban
The voltage for the two countries I will be at in Africa are 240Volts. And the adaptor plug is a type G. So I am guessing it will be OK.
