Charging HD3 thru USB
Discussion in 'Headphones, Earphones & Portable Music' started by pagoda, Jul 27, 2005.
  1. pagoda
    pagoda
    I was wondering if the NW-HD3 actually charges thru USB when the power line is not connected.
    With the power line connected, the red LED charging light on the base turns off when charging is complete. However, with only the USB cable connected, the LED never seems to go off.
    How should we know when USB charging is complete?
  2. kwbarrett
    kwbarrett
    Yes the HD3 charges via USB. It's a little confusing because the screen is telling you to connect the AC adapter. It is charging though. I do it regularly at work. I don't want to carry the adapter with me to and from work everyday.
  3. sbradnam
    sbradnam
    Feb 13, 2005
    32
    North Yorkshire
    Yes it does charge thru USB. I use this when traveling, as I leave adapter at home. Hope this helps.
    SB
  4. pagoda
    pagoda
    Thanks for the responses; glad to know that it actually charges through the USB.
    However, I was also wondering if there was any indication when charging is complete thru USB (i.e., does the red LED turn off?)
