Chapters gone weird on Panasonic DMRE85HEBS
Discussion in 'Blu-ray & DVD Players & Recorders' started by Treetopcow, Nov 3, 2004.
  1. Treetopcow
    Treetopcow
    Hi folks, :thumbsup:
    I very recently bought a Panasonic DMRE85HEBS DVD recorder as a result of advice given on this forum. I have not been diappointed - its amazing.
    I have just finalised my first DVD (-R) but when I play back the DVD, the chapters are not quite where I had edited them to be. Does anyone know why? :lease:
    Thanks,
    Scott
    molaram@blueyonder.co.uk
  2. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    I think we need a bit more information. Are the markers slightly out of position, or are they completely in the wrong place and spaced out in regular time intervals? On this machine if you add markers directly to a DVD-R they will not be kept and they will be replaced by automatic markers (5 or 6 minutes apart). The way to keep markers on the E85 is to place them on the HDD then HS dub to DVD-R.
  3. Treetopcow
    Treetopcow
    thanks
    I'll try the high speed thing.
    I think they were about 5 mins apart (although I didnt time them)
    They certainly were over 30 seconds away from where I put them.
    Scott :eek:
  4. Treetopcow
    Treetopcow
    For some reason it wont let me do high speed dubbing.
    The program I recorded from VHS video on to the Panasonic hard drive was done on XP mode - is this the reason why it wont let me do high speed?
    Please help! Thanks
    Scott :lease:
  5. ben223
    ben223
    To enable HS copying, ensure that <DVD-R for High Speed mode> is set to <On>
  6. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    In XP if the length of the recording is significantly over 1 hour then it can't be HS dubbed (too big to fit). XP mode has been designed such that 1 hour's worth will fill a DVD.
    Just to add to what ben223 has said, it needs to be set to <On> BEFORE you record on the HDD.
  7. Treetopcow
    Treetopcow
    thanks for your help guys!
  8. MuffKing
    MuffKing
    Regarding the chapters, you can't transfer your own or the Playlist to a DVD-R as it will create it's own chapters at 5 minute intervals.
