Channels won't change on Grundig Sky digibox
Discussion in 'Sky Digital TV Forum' started by Barbara2001, Aug 1, 2005.
  1. Barbara2001
    Barbara2001
    Oct 10, 2004
    357
    28
    +23
    I am stuck on Discovery Channel. Pressing the channel up and down on remote doesn't work. Likewise the channel numbers don't appear on screen when pressed on remote. The remote seems to be working as batteries are okay.
    Is this a common fault? Is there a solution other than get a repair man or new box? Thank you in advance for any sensible suggestions.
  2. jenic
    jenic
    Dec 10, 2004
    2,901
    83
    +178
    Switch it off then on (at the plug), wait a minute and press 'sky' on the remote, i used to have a grundid box and i found myself doing this daily, if its less that 12 months old ring sky and make them exchange it for a different make.
  3. Barbara2001
    Barbara2001
    Oct 10, 2004
    357
    28
    +23
    Many thanks for the advice. I will try that. It is fairly reasuring to know that someone else has had the same problem. The box is just over a year old, so it will cost £65 or something like that to get a new one from Sky. I don't want to go that route yet, and I am desperate to be able to change the channel to 130 before it sticks again.
