Channels distorted on freeview
Discussion in 'Freeview & YouView' started by crmcatee, Apr 8, 2005.
  1. crmcatee
    crmcatee
    Running a Pioneer 435xde with Sky which runs no problems.
    When I pick the freeview digital channels - channels 1 and 2 are perfect - three and above are garbage as if the reciever has lost sync, distorted and large scale pixelations all over the place.
    Plug in a normal TV and the pictures fine...
    Before I climb on the roof and reterminate all the cables, any ideas why it does this ?
    Is there a service menu which will show me the digital strength ?
    Thanks in advance..
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    I had the same problem. Aerial needs re-aligning or replacing most likely.
  3. crmcatee
    crmcatee
    upto the roof it is then....
    Cheers - New antenna and leads required then... :)
