Channel Names on sky
Discussion in 'Sky Digital TV Forum' started by aqureshi, Mar 22, 2002.
  1. aqureshi
    aqureshi
    For the last 3 days I can't see the channel names on the screen. apart from that it is working fine. Do I need to force S/w update.
    Asad
  2. Doubledoom
    Doubledoom
    You probably don't need to force a software upgrade. A reset should just do the trick.
  3. aqureshi
    aqureshi
    Thanks for the reply Doubledoom.
    Reset means switching it ff and on again or is there ap procedure for resetting.
    asad
  4. Doubledoom
    Doubledoom
    Just power off at the plug for about 10 seconds.
  5. aqureshi
    aqureshi
    Thanks,that did the trick.
