Channel Five freesat - Media Center
Discussion in 'Satellite TV, Sky TV & FreeSat' started by evolution400, Feb 2, 2009.
Tags:
  1. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Hi Guys anyone on here running a windows media center pc with freesat ?
    I did have Five working fine when it officially launched now I have about 8 - 10 different channel numbers with "five" and none of them work they either say scrambled or no channel etc anyone know what channel number it is and have it working fine in Vista media center ?
    Thanks in advance.
  2. Delh68
    Delh68
    Dec 13, 2002
    1,057
    48
    +55
    10773H 22000 FEC 5/6
    Last channel on the search i believe
    Dunno about vista, but it is the FTA version which doesn't need a card :)
    Hope this helps
    Delh68
  3. Stiggy
    Stiggy
    Dec 7, 2004
    6,726
    Sandy Heath
    +1,043
    I just tried Channel Five - working with no problems here on my Vista PC with a Hauppauge Nova-HD-S2 card.
  4. Sacred09
    Sacred09
    Dec 21, 2008
    34
    +6
    running 7MC here, channel 5 comes in under 'full transponder scan' for me there is about 5 or them only 1 or 2 are not scrambled.
  5. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    thanks guys I think I may try setting up the TV signal again, I alsohave the nova-s2 card I get about 5 - 7 versions of 5 some do show the lock symbol but 1705 and 1706 dont but yet when I try them they say they aare scrambled or encrypted.
  6. fernandez
    fernandez
    Jun 5, 2005
    6,039
    +995
  7. Sacred09
    Sacred09
    Dec 21, 2008
    34
    +6
    Also, just remembered the FTA 5 had no listings, i used the edit guide settings in MC, so it uses the listings from a scrambled 5 ?? if that makes sense lol :)
  8. evolution400
    evolution400
    Oct 10, 2004
    1,165
    38
    Cwmbran
    +17
    Very strange, basically when Five first became FTA I had it on about channel 1705 there was a Five on 105 which was encrypted so I swapped the channels over and was working fine, then admittedly I have not had the need to use Five on Freesat because I have a dual tuner freeview card in my VMC and just discovered when it started to record my programs on that channel and of course they did not record because they were saying scrambled or encrypted so maybe the swap killed Five so full TV setup I think is called for.
