Changing URL link to simple word
Discussion in 'Photography Forums' started by Steve N, May 5, 2007.
  1. Steve N
    Steve N
    Feb 3, 2005
    10,944
    Peterborough
    +2,390
    I want to put the word flickr on my signature like a lot of you guys here but cant work out how to do it from the full URL link
    Ive asked the question 'forum feedback and help' forum but cant understand the reply
  2. allymac123
    allymac123
    May 16, 2005
    2,065
    York
    +435
    what you want to do is copy the the link from your flickr, then (on this forum) type the word how you want it. Then select the word. Once the word you want is selected click the icon above that looks like a globe with a paperclip over the bottom half. This will open up a dialog box into which you paste the link.
    Voila.
    (if it still doesn't make sense post the link and I'll sort it for ya!!)
    <edit> as far as formatting the word goes to make it blue and purple you have to do that yourself. Easiest to do it before you click the "insert link button" </edit>
  3. Steve N
    Steve N
    Feb 3, 2005
    10,944
    Peterborough
    +2,390
    Smashing :thumbsup:
  4. underdog
    underdog
    Nov 19, 2004
    76
    11
    +11
    Just testing.....thanks :)
  5. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    You can use the same method with any link
    for instaNce click
    BELOW;)
    :rotfl:
  6. mwncidur
    mwncidur
    Mar 14, 2007
    212
    28
    Llangwyryfon, nr Aberystwyth
    +44
    Great question. I've been wondering about that for ages. not sure if it has worked though.VVVVVVVVVVV:confused:
  7. mwncidur
    mwncidur
    Mar 14, 2007
    212
    28
    +44
    ignore that got it sussed.
    cheers:thumbsup:
  8. scharf_10
    scharf_10
    Jan 4, 2006
    851
    Near Dundee, Scotland
    +83
    May as well test it here as well. Not linking it to Flickr though.
  9. blackbrickblock
    blackbrickblock
    Jun 15, 2006
    1,643
    Stockton on tees
    +63
    Just thought i would have a go :D
    Flicker
