hi, iv got a technics su x950, which i use for my cd players tuners etc. My question is, iv got a pair of mordaunt shorts ms10s which i want to use as my primary speakers. They use banana plugs, but my amp only takes speaker wire. Obviously i could chop the end of the banana plug but, most audiophiles have said it is more convenient and also will give better conductivity by using a banana plug. the plug on my amp, is a twist on sort of plug. You put the speaker wire in the middle, then twist the plug 90 degrees clockwise. My question is, how can, if i can put a banana plug cable in them, or is speaker wire my only option? Another reason i would like to use banana plugs is so i can bi wire them with some wharfdales i wish to buy soon. Thanks in advance
Regards
Regards
