Changing the Head unit on a Skoda Octavia
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Dishmeister, Mar 31, 2003.
  1. Dishmeister
    Dishmeister
    Mar 31, 2003
    3
    Birmingham UK
    Is possible to upgrade the head unit only in an Octavia and still be able to use the CD changer in the boot? What connection does the original unit have? I want to avoid buying a new head unit and CD changer and then wire them both in.
  2. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    Can't quite answer your question, but the CD changer is the same in our Audi A3 as that in our Octavia.
    I'm only guessing therefore that the CD changer connection is fairly standard fair as the head units in the Audi/Octavia are very different and would guess that you wouldn't need a new changer.
    However, that's still just a guess I'm afraid...
  3. minimad
    minimad
    My best suggestion would be to give someone like Sextons or Toad a call and ask them, they're the experts and would be able to give you an answer in probably minutes.
    That said, although I can't remember which oem is used for Skoda/Audi, I think they use blaupunkt or something like that so would expect that you can control the Autochanger with a compatible hu.
    Collin
  4. dnrc
    dnrc
    Dec 23, 2002
    300
    16
    Near Norwich
    Yes, you want to find out if possible who makes the cd changer, and look for a head unit that is compatible.
    A lot of newer decent quality head units can control most changers with an appropriate adapter. (Try alpine for instance)
  5. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    VAG use a mixture of Blaupunkt and Bose sourced head-units coupled with Panasonic CD-Changers via a Cuustom Cable. I have heard of adding a normal Panasonic CD-Changer via an adaptor to an OEM head-unit but not the other way round. You could try www.edworthys.co.uk ... they're fairly knowlegeable folk.
  6. csayers
    csayers
    Mar 13, 2002
    39
    9
    London, UK
    There is alot of info on this kind of thing at www.caraudiodirect.co.uk click the advice link at the top of the page.
