Changing the Aspect Ratio of an MPEG file
Discussion in 'Desktop & Laptop Computers Forum' started by LV426, Jun 30, 2005.
  1. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,070
    I have some MPEG video files (MPEG1 actually) where the actual contents are anamorphically squeezed (i.e. full frame 16x9) but the meta-tags indicate the files are 4x3.
    Question: Is it possible to alter the meta tags to 16x9, without re-rendering (and hence further degrading) the entire file?
  2. sennen
    sennen
    Nov 2, 2004
    103
    +6
    I believe you can, but I have not done it myself.
    You might like to look at a java application called ProjectX - which I know does have an option to change aspect ratio. ProjectX will allow you to fix/change features of the MPEG file while demultiplexing to audio and video stream files (you would then have to use another tool to remultiplex the streams back to a single MPEG file).
    You can find information on ProjectX and a whole bunch of other useful tools at www.doom9.org.
  3. TheCrow
    TheCrow
    Jul 16, 2004
    612
    28
    London
    +48
  4. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,718
    71
    Land of the Living, Essex
    +34
    Zoomplayer and meedio will both change apect ratio on the fly
  5. groovyclam
    groovyclam
    Mar 28, 2004
    202
    Goto http://www.wincesoft.de/index.html
    On the right there is a menu tree - click on DVDPatcher.
    I have used this tool to patch MPEG2 file headers to change aspect info.
    Maybe it can do MPEG1 as well.
  6. LV426
    LV426
    Jul 14, 2000
    12,840
    +5,070
    Excellent! DVDPatcher has done the job. Thanks, groovyclam. Thanks to the others, too. Restream says it won't work on multiplexed files which is why I tried DVDPatcher.
  7. FruitBat
    FruitBat
    Nov 15, 2003
    3,301
    Ealing
    +382
    A bit late I know ( :oops: ), but probably worth a mention.
    There is something I have used for MPEG2 files. It's called AVestensione and can be obtained from www.offeryn.de (home of PVAstrumento). The beauty of it is that it comes with a registry tweak that adds an option to the right mouse button click in Windows explorer.
