We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Changing psp controls - anyone help??
Discussion in 'Playstation Forums' started by klwalton, Nov 4, 2005.
  1. klwalton
    klwalton
    Have just bought a psp from japan. it seems fine, except that instead of 'x' selecting the menu item, it uses 'o' button. The 'x' does the back function. Anyone know how to change this, or if it is possible to be changed. It is a mode psp-1000. My mate has a psp-1003 and this has 'x' as the selection button.
  2. pspzones
    pspzones
    The us version use the x button whereas the jpn version uses the o button :)
  3. pspzones
    pspzones
    If you upgrade to the us version of the 2.50 firmware software update then this might fix it.
    http:/www.pspzones.com
