Changing pinout on Scart-phono cables
Discussion in 'Cables & Switches' started by cbemoore, Jun 4, 2003.
  1. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    Kicking around in my spares box, I've got 3 or 4 Cambridge Audio Scart to 6 phono cables (wired as composite in/out and audio in/out). They're 75 ohm, and they look like decent quality to me.
    Now I'm looking at buying a Scart->YUV component cable, to connect my Netgem freeview box using component signals.
    Is there any reason why I can't just open up the Scart connector on one of my existing cables, and change the pinout so that it works as a component cable? It would be much cheaper than buying a new cable. Or is there something I'm forgetting?
    Chris
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Can you actaully get component Y-Pb-Pr (YUV) from the Netgems SCART?
  3. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
  4. themadhippy
    themadhippy
    cant see why not,use a straightened out paper clip to push the pins out from the front
