nope - it doesnt do this for the LG5000 series - ive tried it with ALL labels... it doesnt change the icon either... it DOES highlight the label/icon when a device is connected and turned on but nothing happens to picture when i change label to PC....
is this a fault with my TV...? ( LG 32LG5700 )
it seems to be for higher spec models only
EDIT: just tried on my Upscaling DVD player and it did change when put on PC... dunno if any better though
it doesnt do anything with my satellite sky box though - perhaps i could try the HDMI port that DVD is on
also - all it does is BLUR the image slightly which makes it look worse??
it also changes it from JUST-SCAN to 16:9 but seems to have 1:1 Pixel Mapping... so under PC 16:9 means 1:1 , you can only choose that or 4:3 under PC....
well, at least now i know my TV will support the media centre i plan to build hehe - i heard these LGs have problems with PC via HDMI
