changing facia on a Nokia 6310i
Discussion in 'Mobile Phones Forum' started by graham.myers, Sep 20, 2003.
Tags:
  1. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    I've mamanged to break the facia on my 6310i. I've got a replacement but I cant get the old one off.
    I have removed the screws but it still seems to be held on somehow
    any ideas?
  2. bigjonnyauk
    bigjonnyauk
    Apr 10, 2003
    726
    midlands
    +16
    graham i have emailed my mate who knows alot about fones when he gets back to me will let you know mate
  3. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    You shouldn't really be trying to remove the fascia but rather the back casing as this has to come off first.
    Once you have removed the case screws, the fascia bound to the back casing by a series of plastic clips. The 3 clips at the top are very tight but with a bit of careful wangling, the back will come off.
    Now you have to remove the screw holding the internal ariel on (assuming you have got the back casing off) - this is screwed to the front casing from the back. Once done you can simply lift the PCB out and replace in new fascia.
  4. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    that did the trick - thanks
