Changing Denon AVC-10SE to Denon 3803
Discussion in 'AV Receivers & Amplifiers' started by Jasonjo, Dec 30, 2003.
Tags:
  1. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Has anyone changed from a Denon AVC-10SE to a Denon 3803?
    If so, how do they compare? Is it an upgrade or a downgrade?
    I love the 10Se to bits, but I am getting a plasma soon and need an amp with audio delay, hence the 3803 would be ideal (wish the A11SR had the delay feature :()
    Any help appreciated :smashin:
    JJ
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    In features it will be an upgrade...... in sound quality it will be going down
    ad
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Cheers Ad, that was my worry :(
    Maybe a secondhand A1SR then ;)
    JJ
  4. russraff
    russraff
    Aug 1, 2000
    2,313
    Newcastle
    +51
    That's if you want to stick with Denon. There are other, cheaper alternatives that may (certainly in the case of the 7500) still offer an upgrade to the A10SE. The NAD T773 for example, or a H/K 7500, are both good and will offer great stereo performance, too. Have a listen to them both and you may be surprised.
    Russell
  5. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Perhaps getting a listen to an AVR3803 would help. I heard it two weeks ago and - whilst it didn't blow me away - it was certainately very good.
    A second hand A1SR, as you suggested, might be a better bet. I've seen them sell for around £1400 on a few occasions.
  6. puddleduck
    puddleduck
    Jan 24, 2003
    1,816
    48
    Lake District, near as dammit
    +50
    Why not get a projector instead? Much cheaper, better picture, and no need for audio delay...
    (I use an AVC-10SE and Panasonic AE-300 proj...)
  7. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    Well i have a projector and i really need a processor with audio delay cause i have lip sync problems... :lesson:
    But a projector is much better than a plasma, that i agree!: :clap:
  8. thxultra
    thxultra
    Feb 22, 2003
    380
    glasgow
    +4
    I wouldn't asume lip sync is going to be a problem.
    I've got a panny 5 that i used with a 10SE and a freeveiw box and very rarely had lip sync problems , almost never really.
  9. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    Thanks all for the comments...
