changing brake pads on l plate mondeo.
Discussion in 'Motoring' started by GalacticaActual, Aug 31, 2005.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Morning everyone.
    Can any one tell me how easy, or difficult it is to change the front brake pads on an L plate 2L mondeo?
    Never tried it before, but after 4 years of owning it the little warning light has come on saying its time to sort it out. Any help would be apreciatted.
    Cheers.
    Dave. :)
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    no one? :)
  3. rhoamish
    rhoamish
    It's not too tricky, to be honest. But if you've not done it before, make sure you order new shims and split pins, and by a Haynes manual: it's a straight-forward job, but it's worth following a proper guide if you're unsure!
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    cheers mate :smashin: :smashin:
    New shims and split pins? will it bump up the cost by alot of money?, how much is a haynes maual these days?
    Dave.
  5. rhoamish
    rhoamish
    Shims and split pins are only a few quid: ask for afitting kit. It might also be worth buying a tool for compressing the pistons in the caliper (will set you back about £20, but can be used again, obviously!). Don't forget to drain the excess fluid from the master cylinder: you can use a special pipette, or a bit of old sponge, but wash it off immediately if you get any on the bodywork (it's somewhat corrosive).
    I think you can get a Haynes manual for about £15.
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    It is not that hard to do but since the brakes are so critical it might be worth asking around for a friendly mechanic to show you how to do it. A lot of colleges deliver basic car maintenance courses which will give you the confidence to work safely on your car and save a lot of money.
  7. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    dave-s get a big hammer, cos you will need it to get the disks off, with that in mind, a qualified hammer weilder might be better. fordmondeo.org for all your mondeo brake related questions though, alot of help there
  8. Jamp
    Jamp
    Aug 8, 2003
    76
    Sheffield/N Wales/Isle of Man
    He won't need to get the disks off if he's just doing pads, they are a pain to get off when needs be on Mondeos though.
    Many new pads come with some backing stuff that is meant do do the job of a shim now, even if not you can often reuse old shims so long as they're not too corroded. Maybe it's best to get some new ones though as you won't know if the old ones are ok til you've taken them out!
    I would take a digi photo of the caliper before you take it apart, that way you can reference back to it to check it looks ok when you're done. You'll need to squeeze the piston back into the caliper to get it to fit over the new pads, you need a set of big grips for this - like a water pump wrench but bigger.
    If you're not confident, a garage shouldn't charge more than £40 inc the new pads as it's an easy job up on a ramp. Why not get them to do it and let you watch so you'll know next time?
    Good luck :)
  9. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Thnaks for the help guys. Just to let you know that its all done now :smashin:
