Changing a SKY digibox...
Discussion in 'Sky Digital TV Forum' started by peterp, Oct 1, 2004.
  1. peterp
    peterp
    Hi all
    I'm thinking of changing my faulty SKY digibox.I can source one fairly cheaply(much cheaper than what it would cost to call a SKY engineer out).
    Will my existing card work in any sky receiver or will i have to let SKY know that I am replacing my SKY DIGIBOX at my own expense ..?
    Any advice on this greatly appreciated.
    Regards
    Peter
  2. windfall
    windfall
    Oct 19, 2003
    2,422
    48
    LFC Kop End
    +65
    Hi There
    Apparently you will need to call Sky and tell them that you are using a different box and they will do something to allow you to use the card with the new box.
    Should not be a problem.
    Tone
  3. peterp
    peterp
    Mnay thanks Tone
