Changing A Dvd+ To A Dvd-
Discussion in 'Blu-ray & DVD Players & Recorders' started by phelings, Jul 31, 2004.
  1. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    The sticky concentrates on RAM ad -RW,but I have some DVD+ discs and I wondered if there was anyway to copy them over to dvd- other than a standard real time player to recorder copy.I have a Toshiba -RW rewriter in my laptop,which reads DVD+ fine,so can I copy to the HDD in the laptop and back to a dvd- disc?I tried doing a single disc with Nero,which read the disc,but failed before burning.
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,374
    +3,093
    Use DVD Decrypter. Read the DVD - to an ISO image and then burn the ISO image to the DVD +.
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    I want to copy TO dvd- FROM dvd+.Will this also work.Is dvd decrypter freeware
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,374
    +3,093
    Got it the wrong way round.
    Anyway it doesn't matter and it will work and it is freeware.
    www.dvddecrypter.com
  5. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Thanks for that.I tried a +R,but it came up ERROR at 99%.Tried a +RW which read correctly,but once that was finished I could not see what the next step was to transfer to -R.Can you enlighten?
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,374
    +3,093
    You need to use the ISO read mode. This will create a ISO image of the DVD.
    Put the blank in the drive and then use the ISO write mode to create the new DVD.
    It's in the Mode drop down menu.
  7. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Thanks.It worked a treat
  8. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Now thats sorted-are there any programs available that will allow me to convert a PAL dvd into an NTSC dvd using my laptop dvd rewriter
  9. nwgarratt
    nwgarratt
    May 5, 2002
    27,374
    +3,093
    That a whole new problem.
    There isn't one program that can do it. I have done it in the past but it took four or fove programs and several long hours. Also a whole DVD with menu's is impossible.
