Changing 4:3 to 16:9
Discussion in 'Projectors, Screens & Video Processors' started by lostprophet, May 11, 2003.
  1. lostprophet
    lostprophet
    May 11, 2003
    280
    Not the light side....
    +12
    Now this may be a very silly question but I have a 4:3 projector and so watch movies in letterbox mode, I was wondering if it would be possible to mask the lcd panels to remove the black bars and essentially have a 16:9 aspect projector?
    Any halp would be appreciated!!
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,479
    Surrey. UK.
    +2,122
    I made a 16:9 screen, which will do what you want in that respect, but you'll still get black bars for scope movies (2.35:1).
    Is your screen fixed or pull down? There are ways of making variable masking, so you may want to try that.
    Gary.
  3. lostprophet
    lostprophet
    May 11, 2003
    280
    +12
    I just wondered if its possible to mask actually onto the panels in the projector, cutting off the black bars at the source, unless its an anamorphic image in which case I appreciate I will still get black bars, albeit much less so.
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,479
    Surrey. UK.
    +2,122
    The only way to do that is inside the projector, otherwise you get a very fuzzy border. I don't know what kind of material you'd have to use, as it probably gets very hot in there.
    Try it with a piece of card in front of the lens, and see what it looks like.
    Gary.
  5. lostprophet
    lostprophet
    May 11, 2003
    280
    +12
    yeah I'd discovered the fuzzy border thing already. It was internal mods that I was talking about. If anyone has tried this I'd appreciate some advice. Thanks though Gary
