changing 3GS to 4S jb and update advice needed
Discussion in 'iPhone Forum' started by cazshie, Mar 7, 2013.
Tags:
  1. cazshie
    cazshie
    Oct 17, 2008
    32
    I have a jb 3GS and just purchased a 4S.
    What is the correct procedure to transfer all the iphone apps and cydia apps over from old phone to the new phone and jb new phone so that everything works as before
  2. chukwe
    chukwe
    Aug 15, 2009
    5,136
    Welling, Kent
    +465
    Backup your iPhone 3GS in iTunes and restore to your iPhone 4S after jailbreaking it. If I were you, I wouldn't bother restoring your Cydia Apps to the iPhone 4S because of compatibility issues. Most of the Cydia Apps on 3GS wouldn't work on 4S.
    Just manually install all your Cydia Apps
  3. cazshie
    cazshie
    Oct 17, 2008
    32
    So ..
    back-up 3GS to iTunes
    restore from iTunes to new 4S
    upgrade 4S to 6.1.2
    jailbreak 4S
    install cydia applications manually after jailbreak
    .. does that sound right?
  4. chukwe
    chukwe
    Aug 15, 2009
    5,136
    Welling, Kent
    +465
    Backup 3GS to iTunes
    Do Full restore of 4S to iOS 6.1.2
    Jailbreak 4S
    Install all your Cydia manually
    Restore from iTunes to 4S
  5. cazshie
    cazshie
    Oct 17, 2008
    32
    Thanks.
    When I did a restore to 6.1.2 it also restored the previous 3GS backup as well.
    Is this a problem to then jailbreak and install cydia apps or does it not really make a difference?
  6. chukwe
    chukwe
    Aug 15, 2009
    5,136
    Welling, Kent
    +465
    No, it's makes no difference. Did you get all your Cydia App settings back?
  7. cazshie
    cazshie
    Oct 17, 2008
    32
    Not had a chance to jailbreak yet so no cydia apps or settings yet.
    Will jailbreak and try another restore over the next day or two
  8. cazshie
    cazshie
    Oct 17, 2008
    32
    Next query .. Is it possible to transfer apps (not installed via itunes) from my 3GS to my 4S?
