Change TV. To what?
Discussion in 'TVs' started by chriszzzzzz, Aug 18, 2005.
  1. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    978
    Coventry
    +33
    If I manage to get my Samsung slimfit crt exchanged what should i consider changing to?
    I havn't found a tv that someone hasn't had a major problem with in one way or another.
    Are 28's more reliable than 32's?
    Budget would be around the £600 mark...
    Help I'm fast losing any hope in TV land. :suicide:
  2. kp1
    kp1
    I need the same advice please, my budget is £600 as well...
  3. Phill1978
    Phill1978
    Oct 15, 2004
    2,045
    48
    +84
    saw a 32" CRT Phillips wood framed + stand + souround speakers and sub with stand for £600 new in currys.
    CRT`s are soooo cheap, that model used to be £1600 last year.
    get on ebay, get a panasonic, toshiba or phillips 36" for £800 then later when the whole HI-DEF thing has settled in 3yrs when its not 720p res it will be more like 2048 x 1980 of something with no messing just one digital connector get an LCD or LCOS panel.
  4. RMCF
    RMCF
    Aug 24, 2000
    7,000
    +630
    If you stretch to £699 you could get an award winning 36" Panasonic PL32 from Currys/Dixons.
    But its big !!
  5. chriszzzzzz
    chriszzzzzz
    Jun 19, 2005
    978
    Coventry
    +33
    I was thinking of the Toshiba 32zp48 but after having geometry probs on my samsung I am now thinking of going back to a 28 inch something as the geometry problem seems to only affect 32 and above.
    I may even bow and consider an LCD if I'm going down in size. :mad:
