Change res settings to match 26" LCD??
Discussion in 'Desktop & Laptop Computers Forum' started by martind, Aug 4, 2006.
  1. martind
    martind
    Jul 29, 2005
    1,212
    38
    Birmingham
    +20
    What software can i use to change the res settings on my PC so that the desktop matches my 26inch samsung lcd screen?
    Martin
  2. jameslindsey
    jameslindsey
    May 21, 2003
    411
    +20
    Using windows, right click on the desktop background and select properties. Click on the settings tab and there's your options.:D
  3. martind
    martind
    Jul 29, 2005
    1,212
    38
    Birmingham
    +20
    Sorry i didn't make my OP more clear, I was on about an additional piece of software that allows you to amend the screen res to 720 and not 768.
    Anyone??
  4. PeteD64
    PeteD64
    Apr 9, 2006
    692
    28
    Southsea
    +48
    I would expect 1280x720 to be a standard resolution on any modern graphics card.
    What James said is correct about using the settings under the properties menu from the desktop. You might have to dig around a bit under there. e.g. is there an advanced button? If I click that on my PC it brings up further Nvidia menu options & under adapter there's a List all Modes buttons which has hundreds of resolution options including 1280x720.
    If you can't set it direct from windows then the software you need is powerstrip.
  5. martind
    martind
    Jul 29, 2005
    1,212
    38
    Birmingham
    +20
    POWERSTRIP :clap: :clap:
    That's the one i was after!!
    Martin
