monkeyboy69
Established Member
- Joined
- Mar 30, 2002
- Messages
- 672
- Reaction score
- 41
- Points
- 194
looking to upgrade by current centre speaker which is a paradigm cc170. Something just seems to be missing , can't put my finger on it though
I have B&W 602 S2 on the front and thought either a lcr60 or lcr 600 would be a better match.
Has anyone heard the paradigm against the B&W's as I wouldn't upgrade unless the difference was that noticable.
This will all be put through via a sony 930 amp
Also wondering if you have a demo at a store , do they allow you to take your own eqiupment with you usually i.e. could I take the paradigm along or is that a no no.
any help would be appreciated
cheers
cheers
