Change of app region
Mr puffin
Could I ask this forum for advice. I am using a Samsung Tizen (UE43NU7125). I bought (and use) the TV in Sweden. I am trying to install both Swedish and UK apps. By using the usual trick with mute vol up channel up and mute I can change the region for apps. It is quite easy to install Swedish OR UK apps and get these to work without problems. If I set the app region to ALL I cannot connect to internet and therefor can't download any apps. I get the error message that I can't connect to the server (fault 102415). Changing back to either the Swedish or UK region restores the connection but as soon as I try to switch to all regions the problem comes back.
Is there a work around?
Yours sincerely
Mr puffin
LG SP11RA Soundbar Review Coming Soon to AVForums
