Change my 2900 for 2910??
Discussion in 'Blu-ray & DVD Players & Recorders' started by IVOLIC, Aug 8, 2005.
  1. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    Would I see a major difference in purchasing a 2910 and using hdmi connection rather than component on my PJ??
    I know that in theory there is a difference but I would like to know if anyone has a similar setup.
    To my knowlegde replacing my 2900 with the 2910 would be a step down. Would I loose out on CD and SACD performance with the 2910? Replacing it with the 3910 would be the same. Right?
    Any info would be helpful. :thumbsup:
  2. Parklife
    Parklife
    Jun 9, 2004
    557
    28
    +33
    I would not bother with this change. The 2900 is superb through component. HDMI does not automatically give you a better picture. The 2900 replacemnet is the 3910 but I would still not swap. Stick with the 2900 until true Hi-def players come out.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    NO, stick with your 2900
  4. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    Thanks for the reply guys!
    I guess there is no need to change... at least for now. :devil:
