Change Halogen g10s to led?
Discussion in 'General Chat' started by tigermad, Nov 16, 2017.
  1. tigermad
    tigermad
    Jan 2, 2004
    6,475
    Bedfordshire
    +686
    I have a couple of g10 downlighters in the ensuite. Can I just swap these for g10 leds? Thanks.
  2. chrisgal
    chrisgal
    Aug 8, 2006
    1,205
    +98
    Think you might need to change the transformers as well. Well that’s what I did and works perfectly well.
  3. tigermad
    tigermad
    Jan 2, 2004
    6,475
    Bedfordshire
    +686
    Someone told me the transformers are built in. Is that wrong?
  4. nheather
    nheather
    Oct 6, 2004
    19,918
    167
    Horsham, West Sussex
    +10,220
    If the Halogens and LED are both mains 220VAC then yes, just a straight swap.
    Is it a normal on/off switch or a dimmer. If a dimmer then (a) you will need to make sure you buy dimmable LEDs and (b) you may need to change the dimmer to one that is compatible with LEDs. I always advise to just try your existing dimmer first rather than rushing out to buy a new one. But if a normal switch then nothing else to do other than swap the bulbs over.
    Cheers,
    Nigel
  5. tigermad
    tigermad
    Jan 2, 2004
    6,475
    Bedfordshire
    +686
    Hi Nigel. It’s a normal on and off. No dimmer involved at all.
  6. nheather
    nheather
    Oct 6, 2004
    19,918
    167
    +10,220
    And to your knowledge are the halogens just normal mains 220v types, not low voltage with an external transformer.
    If normal mains then just swap out with LEDs.
    Cheers,
    Nigel
  7. Wahreo
    Wahreo
    Oct 11, 2012
    15,440
    +12,725
    GU10’s by their very nature are mains fed.
    Nigel has it.
  8. John7
    John7
    Aug 6, 2004
    2,817
    +982
    If the lamps are bayonet fitting (push and twist) They are GU10 mains. If they are two pin push fit, they will be 12 volt and have an associated transformer.
    If you have the 12 volt type, suggestion would be to replace the whole fitting for the GU10 type, removing the need for the transformer, which will most likely need replacing with an LED driver if you keep the 12 volt fitting.
  9. DPinBucks
    DPinBucks
    Dec 2, 2008
    6,434
    Burnham, Bucks
    +2,000
  10. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,754
    Somewhere in South Yorkshire
    +6,347
    This seems to be getting over-complicated.
    Standard GU10 downlighter bulbs are mains powered.
    GU10 replacement LEDs are also mains powered.
    Simple swap. Full stop. My recommendation would be to err on the side of higher light output (wattage equivalent). Also, watch for the colour temperature - 2700-3000k for a warm white similar to halogen; if you want to go "modern", 6500k is very white white.
    • Like Like x 1
    • Agree Agree x 1
    • List
  11. tigermad
    tigermad
    Jan 2, 2004
    6,475
    Bedfordshire
    +686
    Ok so I’m happy my gu10s are a bayonet fitting and a straight swap for led. The best bulb in the extractor fan has blown and this one is a MR16 12v 35w 300lm so I guess I will have to do a straight swap for another halogen on this one.
  12. tigermad
    tigermad
    Jan 2, 2004
    6,475
    Bedfordshire
    +686
    Doesn’t seem like you can get them any more :-( not sure what to do.
  13. Cocksure
    Cocksure
    Oct 27, 2005
    4,460
    Manchester
    +1,553
    Take the bulb to your local electrical merchants (not diy shop). They will soon tell you what bulb if any you can use instead
  14. DPinBucks
    DPinBucks
    Dec 2, 2008
    6,434
    Burnham, Bucks
    +2,000
  15. tigermad
    tigermad
    Jan 2, 2004
    6,475
    Bedfordshire
    +686
    Got some from bunnings in the end :)
  16. krish
    krish
    Mar 8, 2005
    36,332
    Astral Crescent, Zoovroozlechester, Betelgeuse V
    +17,227
    Bought these recently, still £9.90...
  17. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,348
    11
    13
    167
    ::1/128
    +16,686
    I’ve got so many of them. Been swapping them with colleagues for their halogen ones. I haven’t come across a LED yet that ready does it for me. Ok, besides the Philips Hue bulbs. Colour temperatures are off, the beam is too narrow, the light roll off is too harsh. Just to name a few of my annoyances
  18. ufo550
    ufo550
    Sep 20, 2014
    1,507
    113
    Oxfordshire
    +826
    I don't typically fit GU10 or MR16 lamps in luminaires cans for my clients, but instead the sealed unit fittings manufactured by the likes of JCC, Collingwood, Aurora etc. I'm told by some colleagues however, that the design, output of the latest LED lamps have improved in leaps & bounds. I have some old generation LED lamps in my own house, and are quite satisfied with them. I certainly would not go back to using halogen, simply because they are inefficient and not cost effective, especially in a house populated by teenagers!
  19. stiv674
    stiv674
    Dec 26, 2016
    970
    96
    Wiltshire
    +1,023
    Halogen GU10s are a good source of heat in the winter...
    Have you had many problems with JCC downlights?
  20. ufo550
    ufo550
    Sep 20, 2014
    1,507
    113
    Oxfordshire
    +826
    There was a bit of an issue with the FGLED6's, my wholesaler won't stock them now. The Hybrid 7's had a technical issue at launch. Otherwise its been hunky dory :clap:
  21. stiv674
    stiv674
    Dec 26, 2016
    970
    96
    Wiltshire
    +1,023
    I haven't had many issues with them but I know some electricians who have. I've started using KSR recently.
    I've just about managed to persuade a Halogen GU10 loving client to change to integral LEDs... :smashin:
  22. IronGiant
    IronGiant
    Jun 7, 2003
    66,887
    +47,288
    A testament to how rubbish they are at converting electricity into light :D
  23. stiv674
    stiv674
    Dec 26, 2016
    970
    96
    Wiltshire
    +1,023
    Yes exactly, it's ridiculous how hot they get! :eek:
  24. IronGiant
    IronGiant
    Jun 7, 2003
    66,887
    +47,288
  25. stiv674
    stiv674
    Dec 26, 2016
    970
    96
    Wiltshire
    +1,023
    Haha, very true! One of the many reasons to love plasma TV's, although not particularly efficient...
  26. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,348
    11
    13
    167
    ::1/128
    +16,686
    Oh I wouldn’t like those. I much prefer something where I can Philips Hue bulbs in and control the lighting properly throughout the area.
  27. ufo550
    ufo550
    Sep 20, 2014
    1,507
    113
    Oxfordshire
    +826
    Arrrgh bit old fashioned me, can't see why you want to turn your lights on when down the pub. Its never put off billy burglar. Just use the good old light switch.
    If you do want to go down that road, there's something some much better and properly expensive :)
  28. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,348
    11
    13
    167
    ::1/128
    +16,686
    Oh not just about switching them on remotely. It’s about the ability to create scenes, but foremost quality light. Like with many things light is make makes it happen, yet most of use are happy to put the cheapest bulbs in our homes. Always surprised me.
  29. stiv674
    stiv674
    Dec 26, 2016
    970
    96
    Wiltshire
    +1,023
    I wired a new house a few years ago which was completely home automated, I never saw the appeal of it myself but it was quite impressive, I guess... :rolleyes:
  30. ufo550
    ufo550
    Sep 20, 2014
    1,507
    113
    Oxfordshire
    +826
    Guess whatever floats your boat, and of course it must be somehow connected to WiFi, just to have the latest whatever. :)
