Champions Leage Football, weird effect on sky
Discussion in 'Sky Digital TV Forum' started by vegnomeat, Apr 23, 2003.
  1. vegnomeat
    vegnomeat
    If I use terrestrial TV and watch champions leage on ITV I get a good quality wide screen picture (or 16.9 etc).
    However, if I view ITV champions league via SKY, I get a 4.3 picture of the football, the 4.3 football picture is enclosed within what can only be described as a Picture Frame, it uses the frame to make up the 16.9 picture, has anyone else seen this and do you have a fix for it please.
    Worth adding that the "picture frame" is obviously intentional.
    Wayne
  2. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +148
    I can only assume that Sky only receives the 4:3 broadcast of the football from ITV and then 'pillar boxes' it into a 16:9 window.
    If so, then there's nothing you can do to change it.
  3. gbmitie
    gbmitie
    Apr 25, 2001
    1,139
    49
    republic of ireland now
    +61
    To fix your problem change the setting on your digibox to output in 4:3 while the footie is on and then stretch image etc. Its easier to watch without those frames down the side.
    gb--
  4. vegnomeat
    vegnomeat
    Thanks guys, appreciate the help
    Wayne
  5. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    I didn't think that widescreen could be broadcast over terrestrial? If I'm right about that then the image you are seeing on your TV through this route is the stretched image created by your TV processing.
    On digital TV, the picture is broadcast in widescreen, and the TV detects it as such, but if the originating transmission is 4:3 (ie any football outside of the UK) then the TV company fills in the screen with the intentional frame.
  6. vegnomeat
    vegnomeat
    James, It would appear that you are correct, last weeks game which was "at home" was broadcast perfectly on sky, the previous game "away" had the picture frame effect. Thanks
    Wayne
  7. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Glad I could help
