Ch5 breaking up on freeview.
Discussion in 'Freeview & YouView' started by nightsoil, Aug 3, 2006.
  1. nightsoil
    nightsoil
    Sep 12, 2004
    247
    +3
    All other channels work fine, but Ch5 is all blocky and goes black afetr a while. I suspect the arieal needs to be replaced. Somebody said a signal booster would fix this, but I'm not convinced ?? is it worth a try ?
    thanks
  2. musti
    musti
    Oct 25, 2005
    724
    2
    Leeds
    +50
    I have the exact same problem and I have a brand new £250 aerial. I think if you live in a week signal area channel 5 is bad... I'm pointing @ Emley Moor in Yorkshire but i'm quite a distance from it, down in in a Valley..
    Cmon, its only Channel 5!!!
  3. deanandsara
    deanandsara
    ive been told work is being carried out on the mast at the moment
  4. fallenangle
    fallenangle
    Oct 19, 2005
    404
    +23
    I live in outer NW London and get Ch5 from Crystal Palace (which is outer SE London). Through my ordinary roof mounted aerial analogue Ch5 is unwatchable without a signal booster and then is still pretty poor. But on Freeview through the same aerial and with the signal booster it really is very good.
    You can see that what I think is called the bit rate is low but otherwise it's excellent. But what I do find is weather conditions (particularly high winds) affect the reception on this channel more than others. It pixelates far more frequently than other channels and is seems more susceptible to radio/cell phone interference but I've never had a 'bad signal' complete loss of picture yet.
  5. nightsoil
    nightsoil
    Sep 12, 2004
    247
    +3
    Ok, thanks for the feedback. We are in SW6 so also CP transmitter. Sounds like a booster will help..
  6. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    deleted
  7. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    I've had this for the last 2 day's up in Aberdeen.:mad:
  8. chambeaj
    chambeaj
    Jan 1, 2005
    3,055
    +190
    Channel 5 has been blocking/breaking up on NTL cable this week. I hope its sorted out before the new series of 'Prison Break' starts next year :rotfl:
  9. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    The ONLY way you will ever know if a signal booster will improve your reception is to actually try one or even two together. No amount of speculation can predict accurate results for your
    own particular setup and location.
    Also make sure you purchase a single set booster (this gives the most amplification). The Two (3, 4.) set boosters split the signal so it gets weaker and weaker from each outlet).
  10. jspence2k6
    jspence2k6
    yes it is i hav 1 in mine in it great :thumbsup:
  11. jspence2k6
    jspence2k6
    dose any 1 no were i can get the code for freeviwe EDIT thanks
  12. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,805
    Somewhere in South Yorkshire
    +6,416
    What exactly are you asking for ?
