Android TV with iTunes streaming ect. 2019 is a wild a year
Will be interesting to see how much the 98" version costs. Panasonic's 100" Plasma was £50,000 back in the day iirc. Think I remember John Lewis selling it for £40,000!?
Not that I'd ever be able to get such a large tv up my stairs into the Lounge. Which is a shame as the room is 4.8m x 4m wide and could accommodate a tv 250cm diagonally. With the screen an acoustic panel up to 150" is theoretically possible.
Two years ago, the Sony 100ZD9 television cost £60,000.
That's actually a good point! I live on the first floor of a block of tenement flats and it was an .... interesting experience for Richer Sounds to deliver the boxes containing my 75" televisions up the fairly narrow central staircase. I think that the box containing an 85" television might just be possible to bring up the central staircase, but anything bigger might be a real problem! Which is a shame, because my ideal size of television for my parlour is 90", but no problem, nobody makes a 90" television anyway.
I can only imagine there will be further announcements later in the year. Because right now they've split the XF90 replacements into a 49" XG90 with few, if any, upgrades from last year, and an XG95 range from 55" up that gets the acoustic surface and processor that can actually handle the task of running Android in a non-embarrassing way from the AF9 / ZF9. Then the XG85 edge-lit lacks anything smaller than a 55" either, and the only other new model is a WG66 1080p at 43" or 50".
People that want quality with a smaller set are going to have to go elsewhere.
Are you sure you haven't unwittingly moved into an eternity trick staircase building?£60k! Wow. That’s niche! I’m guessing £25,000 for the 98”.
I live in a townhouse. The first staircase goes up and then turns to the right for the last few steps with a 2nd staircase above restricting head height. 65” OLED box went up fine. 75” might be the limit without removing packaging. Not sure what the limit is!? Maybe rollable OLED or Micro LED panels is the solution!?
And I'm guessing quite significantly more than that, say £40,000? I'd be delighted to be proved wrong, but of course this is entirely a theoretical discussion for me, because even in my parlour (if I want to retain access to my two windows) the largest I could go is 85" or 88". Not to mention that of course I don't happen to have a spare £25,000, £40,000 or whatever the actual figure turns out to be!£60k! Wow. That’s niche! I’m guessing £25,000 for the 98”.
Well, if you are serious and prepared to pay postage from me to you and then from you back to me, I have all the boxes that my three 75" televisions came in, and then you can see if you can get one box safely up your staircase!I live in a townhouse. The first staircase goes up and then turns to the right for the last few steps with a 2nd staircase above restricting head height. 65” OLED box went up fine. 75” might be the limit without removing packaging. Not sure what the limit is!? Maybe rollable OLED or Micro LED panels is the solution!?
So lg the only one with 2.1 HDMI, Imax Enhanced is very interesting
