Can anyone explain how to get the sound from a Centurion PPBDVD8 to play through the TV speakers? It's connected to the front AV socket of a new Panasonic widescreen TV using the 3 pin AV lead. Pictures are fine but the sound just plays through the DVDs own speakers. The manual is not much help! Thanks......
Hi there, Exactly what are the outputs from the DVD player, I have just got the twin screen model and that has separate phono connections. Does yours have a mini jack to yellow/red/white phono plugs. If so I don't see why it is not working, sometimes the sound doesn't come out if you don't have the mini jack pushed in all the way. Sorry can't be much more help, I have a different model. Martin
Got the same problem - the sound does come through to the TV but it's very low. Unfortunately it comes through full volume on the DVD player. Tried different setup options but no luck.
Thanks for the reply! Yes, the TV needs to be turned way up high to hear it and I too have tried searching through the various options. It's a bit disappointing really. I was going to write to Centurion to see what they had to say, but haven't got round to it yet! I've also found it doesn't like DVD copies very much - it tends to freeze - so we're having to take the originals out in the car and hope they don't get damaged!
What are you copying your DVD's on, I use a Toshiba RDXS34 and have not had any problems whatsoever with either DVD-R or DVD-RW, no freezing, skipping or anything. Regards, Martin
if anyone finds anyway of making the volume come out of the TV with no volume from the PPBDVD8 unit, i.e. solely using it as a DVD player, please someone let me know. I also tried fiddling with ALL the settings but to no effect...
Have you tried sticking a headphone jack adaptor in the headphone socket of the Centurion (assuming it has one)? This should mute its speakers but should still leave you with sound on the line out to the TV. If that works but the sound level is still too low on the TV, you could buy yourself a lead that goes from minijack to 2 phonos (lots of people sell them now so you can plug iPods etc into hifi amps) and then run the audio out of the headphone socket into the TV's red and white phono sockets. The volume control of the DVD player will then need to be turned up most of the way and you should get a strong signal. Andrew
I use an in car cassette adapter which plugs into my Centurion twin screen model headphone socket and then into my car stereo cassette player and this mutes the sound to the screens and sounds fantastic on my car stereo, just like being at the cinema. Martin
Sorted, the sound to the TV is controlled by onboard volume and your normal TV volume control. So, stick a headphone audio jack in the rear of the player, stick the volume on the DVD to max, then you can control the sound level from your TV.
