Centre
Discussion in 'Home Cinema Speakers' started by scrapbook, Mar 1, 2002.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,435
    +553
    I am Joe Bloggs your average consumer, do not want anything to flash or expensive just something reasonable.
    I have had a Sony HTK kit for a while which is perfectly adequate for my needs, but I do not particulary like the look of the 5 satellite speakers much (espically the centre which is not flat).
    Some of the Sony HTK kits come with a very flat low profile centre speaker, any one have any ideas if I would be able to purchase this separately or in a kit without the amp. I think the speaker kit is the 225 Pascal range (which I know gets some stick!)
    Alternatively, I quite like the look of the newish(?) pioneer speakers that comes with their low profile DVD/AMP combo set up. The only problem is if you buy them in a kit it comes with a Sub adding extra expense that I do not really need to spend.
    Anyone know if you can buythe Pioneers without the sub?
    Or any suggestions on decent 5 sat speakers for say £200 or less??
