Centre to go with CDM7SE's max width 450mm!!
Discussion in 'Home Cinema Speakers' started by Monster, Jan 11, 2005.
  1. Monster
    Monster
    Oct 9, 2000
    974
    Adelaide
    +30
    Hello!
    I have CDM7 SE's as fronts and have just bought a new sideboard to put the soon to be acquired plasma on.
    In the centre of the sideboard is a space that I want to use for a centre speaker. Unfortunately it is only 456mm wide! Furniture here:
    http://www.mfi.co.uk/mfi/FinalProdu...e Ideas/Contemporary/SanRemo&CT=*&SKU=SRM1131
    The idea being that I will make up a frame, cover it with thin brown fabric (acoustically transparent if possible) and fix it over the shelf area in the front.
    I thought about either a B&W CC6 S2 (about £100-115 on EBay.)
    I could fit in a CMC if I stood it on end. Would this ruin it's performance?
    Another alternative would be to put a single bookshelf B&W in the space but I wasn't sure whether this would be any good as a centre (and I'd have to buy 2!!)
    Anyone's suggestions or opinions would be appreciated.
    Many thanks.
