Centre speaker
Discussion in 'AV Receivers & Amplifiers' started by wolfgang, Mar 14, 2006.
Tags:
  1. wolfgang
    wolfgang
    May 13, 2005
    129
    16
    Glasgow
    My favourite speaker is still the B&W HTM2. However, I can't think of a simple way to place it close enough to the direct view TV screen. Having listened to normal programmes using nothing but the built in loudspeakers of my Panasonic LCD LX500 series TV for awhile I think they are actually very good. So I was wondering if it is possible to hook all of them up as the dedicated 'centre channel'. Have anyone thought of trying this yet?
  2. Miron
    Miron
    Sep 26, 2002
    1,439
    Vienna, Austria
    +56
    apart from telling you that you posted in a wrong forum, i can't help with advice here :D
  3. wolfgang
    wolfgang
    May 13, 2005
    129
    16
    Glasgow
    LOL ...... I am thinking if it the effect is acceptable enough if only the centre channel from the AV32R is divert to the TV's built in speakers. What I am wondering is would the amplified signal from the proccesor would be too high to use on the usual analogue input on the back of the TV.... the one that is usually used for accepting an analogue output from a DVDP.
  4. laalves
    laalves
    Feb 6, 2005
    529
    Cascais
    +8
    It should be a normal line level input, it should work for external sources other than the TV internal tuner itself.
    Luis
