Centre Speaker
Discussion in 'Home Cinema Speakers' started by meg, Mar 2, 2002.
  1. meg
    meg
    I'm looking for a decent cinema speaker set-up, but need a centre which will fit on my Philips WS TV. It's got a slightly curved, and narrow top, and there's no room for the speaker below. Any advice?
    Mark.
  2. robocook
    robocook
    Nov 6, 2001
    137
    19
    Sevenoaks, Kent
    I have a Philips WS also with a slightly profiled top and I've found that three rubber feet, two at the front one in the rear middle works wonders.
    My current Mission 77c1 is held in place with three bits of Blutac and changing the size of the rear blob changes the angle.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,654
    7
    167
    Birmingham, UK
    +10,540
    Your first concern should be to get a speaker which timbrally matches your other speakers.
  4. DaleL
    DaleL
    I have recently bought a Gale centre 20 which was supplied with 4 stick-on rubber feet that you can positon where you like.
    Not sure if it would be suitable as I`m not familiar with your tv,but might be worth a look.
    Have a look at Richer Sounds.;)
