Centre Speaker
Discussion in 'Home Cinema Speakers' started by martin day, Sep 20, 2004.
  1. martin day
    martin day
    Mar 7, 2003
    214
    16
    I have mission 701's as my fronts and 700's as my rear speakers. At the momenr my centre is a cheap gale that cost about £40.
    I know that my missions are quite old now but can anyone recommend a 'good' centre for around £100 that is compatible with the missions.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
  3. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Anything mission should fit your bill nicely.
  4. bobbypunk
    bobbypunk
    Ranges that will sound alright will be
    Ideally The 700 series centre
    But the M7C2 or M3c2 will be fine. Try not to use the 77 series or 78 series as they have a much more delicate sound!
  5. martin day
    martin day
    Mar 7, 2003
    214
    16
    Thanks for the advice guys. Does anyone have the dimensions for the M75 and the M73 as I need to check whether they will fit into my AV rack before I buy?
