centre speaker
Discussion in 'Home Cinema Speakers' started by stevo67, Nov 22, 2003.
  1. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    I think that my dialouge is to quiet coming out of the centre speaker it is turned up full on my amp but it still seems poor
    anybody any ideas
    using
    jbl scs138 speakers & harmon kardon avr 4500
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    is this on DD5.1 or the amp processing?? if proceesing ie TV then try a different mode.
  3. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    i have the same amp and have no probs...not familiar with those JBLs- assume they're some kind of 5.1 package so should be sensitivity and impedance matched...
    have you tried the pink noise db test thru the on screen display?
  4. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    on the avr when watching the T.V it doesnt let me choose anything apart from the following : hall 1 , hall 2 , vmax near , vmax far . it does not let me choose dd digital etc etc , could this be the prob ? is there a way a choose anything diff ? also when watching a dvd with DTS ( harman kardon dvd 25 ) it does not let me choose DTS the avr chooses for me is there a way around this ? , also how do u do the pink noise test noise test on the avr ?
  5. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    if you're watching telly, press Dolby on the front panel to get Dolby Pro Logic II movie
    however, what i use, and what sets this apart from the rest of the amps is the Logic 7 mode. Better sound than Dolby PLII. Simply press 'logic 7' on front panel
    as for pink noise
    press OSD on remote
    then go to speaker levels, and go to test IIRC at the bottom
  6. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    Tried to get the logic 7 mode working but it go`s onto optical and I do not get any sound out of that the only way I get sound is on coaxial 1 and the I can only get dolby and dolby II.My dvd and amp are connected via digital out optical coxial and digital in on the avr
  7. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    i don't understand what you're saying
    can you clearly say what plugs into what
    thanks
  8. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    my dvd player(harman Kardon dvd25) is connected to the amp via optical coxial
    sry if I did not make myself very clear
  9. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    ok, i use logic 7 in lieu of PLII
    you can't use logic 7 in lieu of Dolby Digital or DTS, as they are digital signals. PLII is just an analogue signal
  10. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    now I am confused even more
    think i`ll fone the shop where I bought it as i can not get logic 7 to work with dvd`s at all can get it to work when watching the tv though??
  11. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    logic 7 won't work with dvds Steve
    it only works with analogue signals e.g. tv, vcr, sky (except sky+), analogue out of cd, dvd etc
    doesn't work with digi outs of dvd and sky+
    the avr4500 is a tricky beast- i dont' know about the mp3 and the 192khz dac things yet, and i've had it for a year or so!!
  12. stevo67
    stevo67
    Apr 27, 2003
    54
    9
    ok now it`s a bit clearer thought I was ding somthing wrong or had the wrong type of connections thanx for putting me right
    back to my orginal question :blush: I think the dialouge is quiet to you think this might be my speakers that are at fault .I have tried turning up the centre speaker on the avr but I feel that it`s still poor
