Centre Speaker works with A + B Speakers
Discussion in 'Home Cinema Speakers' started by LDR, Mar 23, 2003.
  1. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Dunno whether this is better off in here or the Amp subforum , but here goes..
    Just connected up a set of speakers in another room to "B" on my Denon 2802, however when I select "B" on the amp the centre speaker from "A" is still working, should this be like this ? :confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    If you have anything other than DIERCT or Stereo selected, yes.
    The amp doesn't know that your speakers are in a different room, it just knows that it has to output to another pair of sockets on it's back.
    HTH.
  3. LDR
    LDR
    Apr 1, 2002
    2,332
    Wales
    +101
    Thanks ReTrO,
    I figured it was something simple, as I always listened in 5ch stereo & my pronto configures the amp that way when I select CD, I didnt think to try DIRECT. :blush:
