Centre Speaker Volume
Discussion in 'AV Receivers & Amplifiers' started by Richard Moore, Nov 2, 2003.
  1. Richard Moore
    Richard Moore
    Sep 14, 2003
    72
    Watford
    I haven't bought any serious AV equipment for a few years so am having to learn stuff now as I go along.
    I had a demo of the Yamaha 640RDS today. There appears to be no way of adjusting the volume of the front centre channel. Is this true / normal ?
    It looks like it will probably end up being a shoot out between the 740RDS , the 640ES and a Pioneer 912. It's proving a little difficult to decide. If there was a 740 without reciever then that would probably swing it. I'm wondering if the 740 is just overkill for my living room cf the 640. The former I can get for about 430 and the latter for 285 from RS.
    Any thoughts are welcome
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    you can change all the speaker levels on the 630rds, so i dont see why the 640 would be different:confused:
  3. Richard Moore
    Richard Moore
    Sep 14, 2003
    72
    Watford
    TBH I think the guy doing the demo didn't really know what he was doing. Either that or he was completely unfamiliar with the kit. Seeing as I was demoing the amp as well as the centre I don't see why I had to point out that the surrounds and sub weren't switched on as well.
    I'd like to support my local shop but I can do better myself.
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    I just bought an AX640SE (£280 from Mr Richer and his 'bonkers' prices!) I'm struggling to get the hang of the volume controls because the front channels go through my stereo amp.
    I think that you change the speaker distance in order to adjust the volume...
  5. Greyhound
    Greyhound
    Aug 23, 2000
    64
    You can change the volume of each channel through the remote control to balance the sound coming from the amp.
