Centre Speaker Suggestions
Discussion in 'Home Cinema Speakers' started by hutchingsp, Dec 30, 2002.
  1. hutchingsp
    hutchingsp
    Looking for a centre speaker to match a front pair of B&W 601 S2's - something from B&W would seem a logical choice, I'd also be interested in any suggestions.
    I'm currently using a £20 Gale from Richer Sounds, fine as a tide-over but it does seem a little "swamped" by the front B&Ws.
    It's a bedroom setup so volume isn't a major issue, amp is a Sony STR-DB830.
    TIA,
    Paul
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +114
    I think you have already answered your own question. Either the B&W LCR60 or 600
  3. Miniholic
    Miniholic
    Apr 26, 2001
    3,054
    The Shire
    +398
    Hi Paul,
    I'll second what petrolhead said, check out the LCR60 (£200), thats what I'm using with a pair of 602.5's, which are more or less a 601 floorstander. The lcr60 has similar drivers to your 601's, so should be a good match, you could try the lcr600 (£350) as the centre does a lot of work, but you might find it a bit much for your other speakers, and £150 buys quite a few discs.
    Hope this helps,
    Ian.
  4. Radiohead
    Radiohead
    Dec 24, 2001
    4,380
    Amazingstoke
    +431
    I'd suggest trying to find a 2nd hand B&W CC6, which was the matching centre for the 601S2's - the LCR60S3 is a fine speaker though.
