centre speaker required?
Discussion in 'Home Cinema Speakers' started by mammoth, Sep 24, 2003.
  1. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    Can anybody recommend a centre speaker to go with a pair of Wharfedale mfm 5 monitor speakers that will be used as fronts please.:confused:
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    The obvious choice would be the Wharfedale MFM Centre
  3. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    No kidding!
    :rotfl: :rotfl: :rotfl:
  4. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    Seriously though,Mammoth...did you expect the advice to be any different?.....the best way of matching your front speakers is to use a centre from the same range,unless size/placement issues make it impossible.
  5. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    As I have had no reply from Wharfedale I was bowing down to experts as to "the next best thing" to matching the fronts with the centre!:eek:
  6. ChrisNic
    ChrisNic
    May 11, 2003
    1,895
    63
    Thame
    +108
    Then after the experts you got desperate and tried round here :rotfl:
  7. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    If you'd mentioned that,I'm sure IanJ wouldn't have suggested the Wharfedale centre.....you should have a look at B&W and Mission,as both have some decent speakers in this sort of price range.
  8. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    Actually this forum was where I started by doing a search and then reading page after page after page before taking the plunge and starting a thread!:p
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    BOSE VCS-10 might be a good speaker to look into
  10. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    what happened to my reply..? has ian j removed it...I think he has, but of course he wan't say anything...sigh...
  11. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,671
    I'm quite sure that if you have something useful to add,that it won't be removed by any of the moderators.
  12. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    I deleted your reply as it was a waste of server space. If you have nothing useful to add to any thread in the technical forums please confine yourself to General Chat.
  13. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    oh, and replies like the above are ok...I know you don't like me, but come on, cut me some slack! I've a quiet spell at work and I don't need hassle!
  14. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    At last a reply from Wharfedale and they no longer make a speaker to match!
    But told me to go for a Gale as a good match but after doing a search I cant seem to find any good words said about them.
    Any ideas?:confused:
  15. SanPedro
    SanPedro
    Jan 11, 2001
    4,528
    +510
    Mammoth
    Will Wharfedale sell a single mfm 5? If you are running the system with a projector, or a plasm, and you can slot it in under your screen why not buy one singly. I've no idea what size these speakers are or whether they are still available.
    My brother-in-law has done the same with a set of Pro Ac speakers, and his is a pretty fancy system by anybodies standards.
    It'll be a tonal match. A lot of centre speakers use the same drive units as left and right speakers and just put them in a smaller box and stick it on its side (basically).
    Don't know if anybody has any reasons why you couldn't place it on its side.
    Regards
    Chris
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    You could buy a wharefdale and remove the drivers and put them in a new macthing box!
