Centre Speaker positioning
Discussion in 'Home Cinema Speakers' started by Tracey, Sep 10, 2003.
  1. Tracey
    Tracey
    Is it better to have the centre speaker higher than the front L/R rather than lower? I've got a new tv stand which has smoked glass doors on the front but when they're open they don't fold back on themselves so having the centre speaker in the cabinet means that I will have to keep the doors open most of the time which doesn't look very nice. The only options I have are to either take the glass doors off which will spoil the look of the cabinet, or have the centre above the tv. However I'm not allowed to have it sitting on top of the tv so the only soltion I can come up with is to build a shelf that sits on the wall behind the tv, at a height just above the top of the screen, would that work if it was further back, than the front speakers? It would be about 400 - 500mm higher then the front speakers but at the moment it's about 400 - 500mm lower.
  2. Neil Porter
    Neil Porter
    Sep 4, 2002
    103
    Ipswich
    I used to have my centre speaker above my TV and it was fine. Luckily mine sat on top of the telly though. Why can't yours go on top? Maybe fixed by some blu-tak?
    If there is a way to try the speaker in the raised position then give it a go to check how it sounds. If it sounds the same (or better!) then go for it with the shelf thing.
    Let's face it, if you like the way it sounds (and looks I suppose) then that's all that matters.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    I have to have mine positioned above the TV,and the sound stage from there is absolutely fine.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I have had centre speakers above and below the TV and haven't noticed any difference. The one thing that I haven't tried is having the speaker both above and behind the TV as I feel that won't work as well.
    It is refreshing to hear from a girl that "her boyfriend won't allow......." just to show that it isn't just the ladies that object to the hardware necessary for AV
  5. Jsinger
    Jsinger
    Aug 26, 2003
    40
    Tracy, your idea of a shelf behind and slightly above the TV is actually a very good one, as it makes a lot of sonic sense to have the centre speaker supported on a stable shelf rather than a TV casing and it's also preferable to have the centre speaker slightly behind the L/R channels in an arc arrangement.
    Mounting the centre speaker directly on top of the TV case itself is probably one of the worst places to site it unfortunately, even though it's the most obvious/only option for most of us.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Please explain your reasoning.
  7. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +230
    An arc to ensure the speakers are equidistance to the listening position?
  8. Jsinger
    Jsinger
    Aug 26, 2003
    40
    Unfortunately it's not my reasoning, but that of those who probabaly know a lot better than us. Please see the foot of this page: Ideal Surround Speaker Placement
    And your reasoning for this is?
  9. Tracey
    Tracey
    I've just realised that maybe this is a bad idea anyway as we soundproofed the wall so don't really want to be making holes in it. I've been looking at the B-tech brackets that are available in black, it's either that or off come the glass doors. I also thought maybe I could get some new glass doors made that are smaller so when they're closed the centre speaker is still on show.
  10. Tracey
    Tracey
    He wasn't happy when I showed him the MJ Accoustics Ref 1 that I want, even though I told him I was getting the smallest sub I could, just for him! A storm is definiltey out of the question. :mad:
