Centre speaker positioning
Discussion in 'Home Cinema Speakers' started by nigels0, Oct 9, 2004.
  1. nigels0
    nigels0
    Sep 7, 2004
    42
    Can I have some advice/opinions?
    Most centre speakers are below the screen, but I'm putting a plasma on a wall and I want to get it as low as possible as it is going above a fireplace. Is there any reason why I can't put the centre speaker above the plasma instead of below?
  2. John
    John
    Dec 13, 2002
    11,316
    +2,932
    Nope , mine is above the plasma (keeps it out the way of little mits).
    have a look at the plasmas out thread , every concievable set up is in there :smashin:
    atb
    JS
